Throttle too sensitive when on to off
Tim ma
Post by Tim ma »
My DC5 type R just installed a Kpro with base map K20a.
When driving the car 1-3gear low speed at 2-3K rpm, then close the throttle to 0%, it was stop accelerate very suddenly, no need to use brake to stop behind the traffic light, the engine brake totally too much for daily drive, i have no idea whether this is setting problem or calibration issue.
Anyone have idea I appreciated
Tim Ma
Re: Throttle too sensitive when on to off
Post your calibration as well as a datalog showing the issue.
Tim ma
Post by Tim ma »
Here are the file, thanks you very much
Has this been properly tuned on the dyno?
It is normal when the throttle closes and you are decelerating for the injectors to cut off.
Tim ma
Post by Tim ma »
If this is normal, it must be the problem of daily drive, big difference between stock ECU when throttle closes, it is stuck when get into traffic jam
tehlonz
Post by tehlonz »
You may also try adjusting the idle solenoid duty if you feel the rpms are dipping too greatly.
Tim ma
Post by Tim ma »
Tehlonz, i don’t get yr meaning, adjust TPS angle or idle Rpm?
Your support appreciated
fonzeka
Post by fonzeka »
He was talking about the Idle Valve Duty Cycle https://www.hondata.com/help/kmanager/i ... meters.htm
