Modifying the VTC on a TSX
k24a2turbosol
Post by k24a2turbosol »
hey my question is simple how to modify the VTC cam on my tsx k24a2 so i can get teh 45 degrees ??
what tools and how hard ??
lots of thanks if you coudl tell me how and if i would benefit from this
i have my redline set at 7600
k24a2
kpro
type s tranny
crv throttle body
t3 turbo 10psi
fidanza fly
exedy clutch
hondata img
650 cc venoms
aem fuel
hasport mounts
You need to get two lobes of the VTC inner piece machined. A good machine shop can do this, but you'll have to do the measurements and work out how much to machine off in order to get 45 degrees (hope you remember what trig is).
k24a2turbosol
am i correct in saying that i want a tsx intake cam and rsx exhaust cam for a turbo engine?
and also does the type s VTC bolt onto my tsx cam
Razathorn
Post by Razathorn »
k24a2turbosol wrote:am i correct in saying that i want a tsx intake cam and rsx exhaust cam for a turbo engine?
Regardless of if they do or not, the vtc on a type-s k20a2 does 50 degrees of cam rotation where as hondata determined the maximum they felt safe doing on the tsx motor was 45 degrees -- past that and you run the risk of kissing valves.
You must measure the volve to piston and valve to valve clearance anytime you change the cams and/or VTC.
