Adding Flex fuel sensor to Bosh ECU
slicksta637
Post by slicksta637 »
I was wondering if it is possible to install a flex fuel sensor to the car and wire it to the ECU so that I can monitor ethanol content. What parts and flex fuel sensor do I need to order and what pin do connect to to get the signal to the flash pro?
Re: Adding Flex fuel sensor to Bosh ECU
The FK2/FK8 does not support flex fuel.
slicksta637
So the Flex fuel display setting on the Hondata app is not accessible? I was just hoping to be able to display the Ethanol content and not need a separate display. Will there be any future possibility of this being an option?
