Smanager wish list
V-Spec race development
Post by V-Spec race development »
kesnut wrote:develop the romeditor cable to work with the s300 software, tune with your s300 save it as a bin an burn it to a rom for s200 and s100,
one software to rule them all
I would like to see this as well as I tune both.
T66crx wrote:I would also like to see the ability to lock the chip with a password so no one can open or download the file unless used with a password
I agree to that and cannot be modified by someone that don't know what they are doing and mess up the tune and blame the tuner for what happen to their motor.
Manny1987 wrote:In Crome Pro theres options to select certain injector information. For example High or Low impedance injectors and the voltage compensations, & by manufacturer.That way everything is dialed in for you as far as MS's and dead times etc. Is there any ideas of ever making or adding an options like this for at least a majority of the leading injector manufacturers. I know theres compensations but maybe this would help many people tune there cars.
I would love to see this implemented as I'm using 1600cc injectors and thinking of getting even bigger and it's a pain in the neck w/o having to know the dead time and voltage value etc.
allm0t0rGSR
Post by allm0t0rGSR »
rev limiter and shiftlight for every gear 1-5 like neptune have would be great...
hdragster
Post by hdragster »
Hondata already features shift light and rev limiter you just have to put it on!
hdragster
Post by hdragster »
Corrected 02 wideband reading
allm0t0rGSR
hdragster wrote:Hondata already features shift light and rev limiter you just have to put it on!
i know but what im trying to say is that every gear single gear, u can set diff rev or shiftlight each gear...
Tsuchinoko
Post by Tsuchinoko »
A diferent color for the cell you already change the value. Like this you will know that you already change that specific cell.
Those who know don't tell, and those who tell don't know.
ehhbuddy
Post by ehhbuddy »
Ability to have a hotkey to implement all recommended changes then we can adjust from the recommendations this would save alot of time.
lowblow
Post by lowblow »
is there any where for S300 work together with after market EGT sensor ?
lowblow wrote:is there any where for S300 work together with after market EGT sensor ?
It has had this option for a number of years. http://www.hondata.com/help/smanager/se ... alog+input
Luke
Post by Luke »
the O2 reading should be better.
when putting in a wideband i always have to look for a offset.
can't that be fixed somehow?! it costs some time each time, before tuning.
best regards Lukas
lowblow
Post by lowblow »
Thanks ! Spunkster , which EGT sensor best combination ?
for input analog 2: R2 and R3 need removed replace with 1 or 2 1N4148 diodes ?
PLEASE !
Luke
Post by Luke »
@lowblow: i recommend the PLX EGT-sensorbox, because it give you an output from 0-5V.
for the using the input, you should read the helpfile. it's written there exactly what you have to do, that it works properly.
best regards Lukas
lowblow
Post by lowblow »
THO CHER LAY ! (THANK YOU VERY MUCH ) in chinese cantonese
my MECHINE gonna run SMARTER with all this SENSOR !
