KManager V1.4.5.7 Beta
KnightX
Re: KManager V1.4.5.5 Beta
Post by KnightX »
Spunkster wrote:Who is the manufacturer of your computer?
Acer
Corey872
Post by Corey872 »
The one giving me troubles is a Gateway NV79.
Corey
E85 fueled Acura RSX-S Turbo w/ KPro
∙ 12.5:1 CR ∙ Precision Billet 5857E @ 15psi ∙ OBX Sidewinder ∙ ID 1000's ∙ ACT XTSS ∙ OBX LSD ∙ Custom 3" Magnaflow SS Exhaust
What is the user name you are running KManager from?
Also, because Windows does not change the user data store if you rename a user, what are the user directories under C:\Users? Should be 'All Users' etc.
Re: KManager V1.4.5.6 Beta
V1.4.5.6 has been released:
• Added table axis tracing.
• Changed the 3D table tracing to accurately show the cells which are being read.
• Disable print and printer setup if no default printer is present.
There also are some minor changes for Windows 7 logo compliance - eg the manifest resource was changed to always use themes and set request privileges, the uninstalled was digitally signed and given the version number.
Corey872
Post by Corey872 »
Yay! the .6 version fixed my 'won't open' issue. Now seems to be running fine under my main user and with BD running.
Corey
That's good to hear. The cause was probably the application manifest not requesting the right privilege - but odd that it would only happen to a few people.
doms22
Post by doms22 »
hello ,
Decimal impossible on the table Wideband input option voltage
Application: Hondata KManager 1.4.5.6 - [Table]
Time: 3/05/2011 12:11:42
Expection: EConvertError
Message: '11.4' is not a valid floating point value
Class: TColorStringGrid
Form: SettingsForm
Control:
Stack trace: 0x02f30570 0x004e1086 0x0042f9d2 0x0051de21 0x0051f0d9 0x0051d4f8 0x0051d572 0x0054627f 0x005492ac 0x004dbb0e 0x7e398734
People using decimal separators other than a period:
Do you want to enter decimal numbers using a period or a comma?
Do you want to display decimal numbers using a period or a comma?
What makes the most sense to me is to allow numbers to be entered with either a period or regional settings decimal separator, and display the values according to the regional decimal separator.
VT-Doo
Post by VT-Doo »
I've been using 1.4.1 since my last reported problem as i haven't had time to keep uploading everytime I drive the car.
I just had a go with 1.4.5.6 and the same problems persist. the S.Trim goes haywire as I described before. I made a datalog but the "violations" wouldn't send and it ended up closing KManager, and the datalog!
Ian
Morris Mini (B18C-R)
Honda Civic Type R (FD2)
Honda Civic Type R (FK2)
Try clearing security before you upload the calibration.
rikitaun
Post by rikitaun »
doms22 wrote:hello ,
Form: SettingsForm
Control:
jajajajaaja... I have the same problem.. !!! fucking euro !!!.
Try it, go to windows Control panel --> "regional configuration"
Set decimal simbol as "point" and millar simbol as "comma"
I've spent the last two days revising the use of regional settings, and are in the process of testing. This will fix your problem.
VT-Doo
Post by VT-Doo »
My problem? If so it's very much appreciated :)
Do you need to see my calibration and datalogs showing my the problem?
Ian
Maverik
Post by Maverik »
WOT fuel compensation and catalyst protection tables ...do they work for PRA ECU (European Civic Type R)?
When "use stock knock control logic" is enabled, which values are taken from the knock tables under boost conditions? ...there are no boost columns, so I guess the ECU uses column 10 values ...is that correct?
Andrie
Re: KManager V1.4.5.7 Beta
Post by Andrie »
What is purge system? Also, I installed kpro with rsx sideband on the S2000, I've been getting error code os secondary o2 heater error. Why is that? Is my option only to disable it?
