2007-2008 TSX Reflash or Flashpro support?
JDM_ES1
Re: 2007-2008 TSX Reflash or Flashpro support?
Post by JDM_ES1 »
Is there any hope for us 07 - 08 guys after a year? If not I may have to just bite the bullet and go with the K-Tuned setup as I've finally saved enough to do some motor work to the car.
JDM_ES1
Post by JDM_ES1 »
Any hints as to if I should wait? I'd really like to use another Hondata product rather than anything else out there but I dont want to hold out if nothing is planned at all??
Spunkster?
We are looking into options, but at this time we do not have any information.
JDM_ES1
Post by JDM_ES1 »
I see, thats fair... Guess its always going to be one of those hush hush things and if it happens it'll just pop up! sighhh lol
mymusicveins
Post by mymusicveins »
Any updates on this?? Id really enjoy this car more with this reflash
Your patience will be rewarded soon.
mymusicveins
Hondata wrote:Your patience will be rewarded soon.
Very exciting!!!
juri
Post by juri »
Hell yes!
prosem
Post by prosem »
Yes, this is very exciting!
Any chance it is before xmas?
December 2011
FD2_CiviK
Post by FD2_CiviK »
Just to be clear. When flash pro is released next year for the 04-06 model tsx. you wont need to purchase a 08 ecu correct?
You will need an 07-08 ECU. That ECU plugs into the 04-06 TSX, and it also needs some wiring to the OBDII port.
mymusicveins
So will there be an ecu reflash AND flashpro, or only flash pro?
Also if flashpro is the only option, are there any preloaded maps like the one you used for the reflash for the 04-06?
Lastly, if flashpro is the only option, is there any way to change the shifting parameters on an automatic? Like speed/firmness of the shift, or downshift throttle %'s, things of that nature? The one thing that drives me up the wall with the automatic is if your performing a rolling stop and then gas it, the gear usually stays in second, where Id prefer the car to downshift back into first without having to floor it.
Just speaking out loud, wasn’t sure what the flashpro could handle/control and to what extent
We are selling a FlashPro as from today. There are a couple of starting calibrations. For automatics the transmission computer is a separate processor which we do not reflash.
mymusicveins
Ok, so is one of the starting calibrations the same as the reflash 04-06?? I don't want to have to tune and figure out settings if you guys have already have a good tune ready to go that is tried and true.
