Individual cylinder ignition trim
csargemg
Re: Individual cylinder ignition trim
Post by csargemg »
Wow thanks! You guys are really awesome.
typer86
Post by typer86 »
At the moment I am playing with this setting to get a smooth running engine. (Finally tuned with all cylinders are zero)
With the new setup I found out that the mixture tends to get leaner if you advance the ignition. Is that normal?
Cylinder number = #
#1=1 #2=-1 #3=-1 #4=1
The car is running in open loop aproxx. 2-3% leaner.
In WOT all normal.
Is that normal?
onogaiaa
Post by onogaiaa »
I don t understand in hondata helo individual cylinder ignition the graph example please
onogaiaa wrote: Tue Aug 21, 2018 9:27 am I don t understand in hondata helo individual cylinder ignition the graph example please
I don't understand your question.
onogaiaa
Post by onogaiaa »
This example https://www.hondata.com/help/flashpro/i ... nition.htm i don t understand why decrease on cylinder 1 if not hace knock in the test
