Can't datalog PLX wideband below 1.2V
no just the 2 listed
Honda9ower
Post by Honda9ower »
Thanks, it was a bit of a daft question after looking at the ECU. What looked like 4 resistors in the photo is actually the 4 solder pads, 2 for each resistor.
Anyway, removing the resistors fixed it. I can now log the ELD voltage down to 0.1V. Thanks for the assistance, I'm now off to do a bit of (full wideband!) tuning.
JustinC
Post by JustinC »
Finally a solution, I think hondata should make this information a sticky for people having similiar issues.
The Spectacle
Post by The Spectacle »
I can also confirm this fix works. Hondata, please add this to your FAQ/help file for others
SPOOLIN
Post by SPOOLIN »
my plx is being tricky to get it to read right on hondata, so i guess in general, removing those resistors will help anyways?
What ive noticed is that the response on the s300 display for the wideband is slower than the actual wideband, shouldnt it be just as responsive and quick as the actual plx display?
www.MSSRACING.com
9.29 | 6.20 | 167
bewize
Post by bewize »
will that work the same on PRA ECU (EU EP3)?
and why there aку 2 resistorsб not 1?
camoy
removed resistors
Post by camoy »
So just to be sure after I removed the resistors I can leave the circuit open? I don't need to solder a wire back in the resistors place?
The Spectacle
Re: removed resistors
camoy wrote:So just to be sure after I removed the resistors I can leave the circuit open? I don't need to solder a wire back in the resistors place?
correct
rkhan
Post by rkhan »
I am having the same problem on my PRA ecu with PLX AFR wideband.
How many have tried this and worked?
This is a bit tricky
The Spectacle
It works, trust me.
93supercoupe
Re: Can't datalog PLX wideband below 1.2V
Post by 93supercoupe »
this should be stickied. Furthermore, Hondata should tell people about this when a customer calls with a similar issue.
It depends on the output current of the wideband. Most are ok.
