FlashProManager V1.1.5.6 (beta) - US MT R18 support
civicRSA
Post by civicRSA »
Above zero strim it will show the + values. Below zero there is just a blank for the strim.
Pir8pete
Post by Pir8pete »
[quote="Hondata"]Pir8pete: Shift+F1 or View->Normal
How did this get changed? I never touched anything just ran the install over the exsisting installed version. Is this a default setting in this .1 version?
civicRSA: Does not do it here. What regional settings do you use?
civicRSA
Post by civicRSA »
Regional settings checked all reset. Still doing it.
With V1.1.5.3 we have added the gear ratios. These are used by cruise control to determine if the clutch is slipping, and will cancel the cruise control at a certain point.
Would someone with a Euro CTR try a MAP calibration and tell us if cruise control works in 6th gear? You'll need to change the ratios from the default.
civicRSA
Post by civicRSA »
I'll get on it. Will report back.
civicRSA
Post by civicRSA »
Confirmed. Speed cruise in 6th gear works on Euro CTR using MAP calibrations.
Well done Hondata
Thanks for checking this.
Gernby
Post by Gernby »
Will ignition retard by gear be available for S2000's anytime soon?
'06 NFR S2000
civicRSA
Post by civicRSA »
I see the function to disable the second coolant temp sensor.
I thought that you could disable it by un-checking use second coolant temp sensor for fan control.
Does this have and influence on the wideband input here?
If disabling the ECT2 can you not use ECT2 to control the fan?
Gernby: probably not.
civicRSA: It is for race cars.
Gernby
Post by Gernby »
Hondata wrote:Gernby: probably not.
Is that due to a technical difficulty, or just due to priorities?
'06 NFR S2000
civicRSA
Post by civicRSA »
Hondata wrote:civicRSA: It is for race cars.
So when using ECT2 for a wideband input which do you disable?
ECT2 sensor or ECT2 fan control
Gernby: I have not looked to see if it is possible for the S2000 yet, but at the moment it is not our highest priority.
civicRSA: Just disabling the ECT2 should be enough.
Gernby
Post by Gernby »
Now that the "Return To Stock" function has been moved, how can it be uploaded to the Secondary Calibration on the FP? I always keep the RTS calibration there as a backup.
'06 NFR S2000
