Proposed fixes and ideas?
Re: Proposed fixes and ideas?
Some of the file related errors are UAC related (for instance, when saving into the Program Files directory), other file errors tend to be re-saving to a calibration or datalog downloaded from the internet, but in this case it could be the directory path doesn't exist.
The exception reports are not stored, and so you do need an internet connection to send them. However, with the number of people using our software we tend to get 10-100 copies of each error, so as long as some people send the exception reports we get them.
A no-start security feature is a good idea. It depends if the ECU monitors some of the inputs (cruise control is the first I thought of) when the engine is not running.
myuser
Post by myuser »
Hi,
This is an overview of some new issues found. From old ones (soooorrrrry) to recent ones.
Some old ones remain in the new version.
Version 1.2.8.0
  • Load multiple datalogs... one after another. Just loading.
    Application: Hondata FlashPro Manager 1.2.8.0 - C:\Sense\Hondata\Flashpro\FlashPro\Maps\Hybrid.fpcal* - [Fuel low - 0 degrees]
    Time: 19-05-2012 01:47:00
    Expection: EStreamError
    Message: Out of memory while expanding memory stream
    Class: TMainForm
    Form: TableForm
    Control:
    Stack trace: 0x7525d36f 0x0049608b 0x00507cdc 0x0043f6f9 0x0043f5fe 0x0049c316 0x0056449b 0x005674c8 0x00567143 0x0049c97e 0x7675c4e7
  • Check updates
    Steps: Help -> Check for Updates -> Found new version 1.3.1.0 -> Yes to download -> gives the following error:
    C:\Users\R\AppData\Local\Hondata\FlashPro\update.exe is not a valid Win32 application.
    New Dialog in 1.3.1.0 fix this issue (Nice approach)...
Version 1.3.1.0b
  • Delete All button from Datalogging tab sometimes does not refresh the values like Used,Free, ...
    Example: After saving the datalog press the Save As... (button), Cancel, Delete All (button), Yes
    with more than one datalog (to Test); only one datalog (Ok). Hibernation could cause some issues if FPM is running and no FP? :S needs more detail...
  • Loading new datalog that is not present in datalog menu entry. Before loading this new datalog
    we make a change in seting the new start and saved with other name and notice that the
    entry in menu Datalog was changed either with two names (was performed Save as...?!?)
    Application: Hondata FlashPro Manager 1.3.1.0
    Time: 03-06-2012 11:30:48
    Expection: EAccessViolation
    Message: Access violation at address 005681C3 in module 'FlashProManager.exe'. Write of address 00000000
    Class: TMainForm
    Form: GraphForm
    Control: cboTemplate
    Stack trace: 0x005681c3 0x004cfca8 0x004cf1b0 0x0042f9b5 0x0042f8ba 0x0055101a 0x005bd60b 0x005c0638 0x005c02b3 0x00551682 0x7675c4e7
    Out of memory??!?!?!
    One way to see this is to remove the first loaded log this should be the 0 in the menu. (FIFO method)
Version 1.3.2.0b
  • In the instalation of 1.3.2.0 the first dialogbox show that we are about to install 1.3.1.0
  • Saving the datalog using "Save as..." button the title remains with the same name.
Some wishes that could improve :)
  • Improvements in Graph-XY like add a simple button to "Plot"(apply the refresh) and remove the combobox action to refresh. This way if we want to change the two combobox values we must wait two times to plot the graph.
  • While the Datalog is running some properties in the display like change sound and other settings prevent the property dialog from responding to the user command. The user have to forcelly shutdown the flaspro manager if the datalog is time consuming. The datalog must be stoped before
    the change is made, or let the datalog reach to the end.
  • Possibility to define (different lunch control value [live]), and/or the possibility to add functions in control by FlashPro in memory (allocate dataloging memory to use some functions) until next start (car start) this possibilities could change lunch, rev limit by gear, flash light (MIL light) by gear; this will only be in memory and be usefull in drag and other events where every pull could be improved; this way preventing from re-flash over and over.
It's great to always improve the software and add new cool features.
Thanks Hondata!
Best regards,
JP
AlexWoods
Post by AlexWoods »
Apps to use flashpro with android tablet. At least datalog with real time display.
