SManager software requests
Re: SManager software requests
What is the sensor input that is being used?
turbo-2nr
Post by turbo-2nr »
any chance of boost by speed,its easy to convert an abs sensor to read ground speed witch would help control tire spin
locash
Post by locash »
D12 and B6 are being used commonly, as on one car we have exhaust manifold pressure and fuel pressure, some cars use it as a wideband input when they are also using a stock sensor on D14..
I guess a pulldown selection of common sensors would be better than nothing, but having it in the calibration makes more sense.. :)
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
locash
Post by locash »
Boost by speed isnt as easy to implement as one would think. I suppose if they set it up based on the OEM VSS, then you could find a way to use that VSS input to be triggered by the rear wheel speed sensor..
Locash Racing, LLC
turbo-2nr
Post by turbo-2nr »
yes it would be based for the stock vss, we would have to figure out howto make it work with an abs sensor as long as there was a voltage offset it wouldn't be that difficult on the user end
Luke
Post by Luke »
http://www.adelante-it.de/datasheets/MB-C04.pdf
here a datasheet for a SPP Bluetooth adapter. with something like that, there shouldn't be a big deal to add bluetooth to S300, KPro etc.
best regards Lukas
locash
Post by locash »
Bluetooth seems like a big waste of resources. I know of another system that supports bluetooth, and nobody cares or uses it.
Locash Racing, LLC
Luke
Post by Luke »
locash wrote:Bluetooth seems like a big waste of resources. I know of another system that supports bluetooth, and nobody cares or uses it.
just to tune it's wasting recources.
but in combination with datalogging, with apps for smartphones that could show the display, log the data, messure some data (HP/torque calculation, like those streetdyno apps, but on bases of the increase of the engine speed combined with the GPS signal) etc.
in this case this could be pretty interesting.
EDIT: maybe an option of rotating the 3D map would be nice and some calculation options (datalog of revs for calculating the torque, so some kind of streetdyno based on datalogs)
best regards Lukas
Johnny_9
Re: SManager V1.5.1 beta
Post by Johnny_9 »
Luke wrote:a selectable target lambda option would be great, one for the primary map, one for the secondary map.
well, and more breakpoints than 3 in the options.
*sorry, wrong thread...*
best regards Lukas
Excellent to see support for this feature request :-D
Luke
Post by Luke »
best regards Lukas
in my opinion that is a MUST HAVE for detailed work.
best regards Lukas
SPOOLIN
Post by SPOOLIN »
The ground speed sensor ability is a great request
a sensible one also is date stamping or showing the time and date in the Datalogs list.
www.MSSRACING.com
9.29 | 6.20 | 167
Johnny_9
Post by Johnny_9 »
best regards Lukas
best regards Lukas
My fingers are crossed, since it is already implemented in K-Pro! :-D
jiggacivic
Post by jiggacivic »
how about to make the redo/undo buttons greyed out when they cannot go anymore.
Luke
Post by Luke »
what about to a setting which says how fast the RPM at the limiters recover? meaning: hitting the rev limiter and you can decide if the recovery is 200rpm below the limiter or 20rpm, in example.
same thing of course for LC and FTS
is that possible?
best regards Lukas
Bluetooth: It's not as easy as you might think because the s300 does not use a serial protocol.
Rev limits: Very early on we found that setting the recovery very close to the cut point was best.
