S300 V2 Digital input
crixzc
Re: S300 V2 Digital input
Post by crixzc »
Thank You
RyanR
Post by RyanR »
I'm running into the same problem with an LC-2 hooked up to the serial in. I'm running the serial out on the LC-2 to I- digital in on the s300 v3 and it's reading roughly half of what the gauge attached to the LC-2 displays. I tried hooking up the ground from the serial out and there was no change.
rondoval
Post by rondoval »
Same here, as already mentioned last year on this forum...
LC-1 hooked up to S300 V2 (SManager v2.3.3). Readings from the digital input are half of what is shown by LogWorks or logged on analog input (i.e. AFR=14 gives a reading of 7 on the digital in).
crixzc
Post by crixzc »
Hondata? How did your testing go?
crixzc
Post by crixzc »
Hondata wrote:We can test it again, but we have not made any alterations in that area and I would expect it to work. It will take us a few weeks to be able to test this.
We've made some changes to the LC1 digital input which should fix this. We think the LC1 digital steam was getting out of sync. It doesn't have a checksum for the digital packet, you you can't tell if the data is valid or not.
RyanR
Post by RyanR »
So will these changes be implemented in the next version of sManager?
Yes. However, we don't have a release planned for a while.
