CPR Issues - breaking up, won't rev
Gohardjersey
Re: CPR Issues - breaking up, won't rev
Post by Gohardjersey »
I need to follow up with my situation, after a long frustrating series of process of elimination my issue was in fact my issue and Unfortunatly was the last thing I tried in regards to a poor idle and breaking up after 5000. I use a millspec raychem harness. I new I was going to get the cpr so I had my harness builder incorporate cop into my main harness. I had a coil pack harness made that deutch connected into the main harness. When the cop harness was made the thermostat ground was removed by the builder. He previously made them this way without issue. I sent the cop harness back to him and he added the ground and the car runs 100% again just from that ground.
Thanks for the update - it does help us a lot to find out exactly what the problem was. I hope everything goes well for you in the future.
Gsrmike
Post by Gsrmike »
Having the same problem thought it was a fuel problem.
Any updates or ideas from hondata about this?
I relies this was 2 years ago have you all found the problem.
The issue with my car is it runs fine but after one 1/4 mile pull it start the breaking up shit but sometimes it will run fine.
This sounds like a loose wire or non-oem coils.
Gsrmike
Post by Gsrmike »
Using oem coils what wire looses you suspect? Ecu pin
I gonna try ground wires and maybe a different oem dizzy.
Those would be good places to start.
Gsrmike
Post by Gsrmike »
Ok thanks but this does sounds like a wide spread problem with the cpr
Almost every problem we have seen turns out to be a wiring or distributor problem.
Gsrmike
Post by Gsrmike »
Spunkster wrote:Almost every problem we have seen turns out to be a wiring or distributor problem.
Ok thank you my friend I will really
Look into the wiring and and a dizzy thanks for your help hope to solve this soon as I am very confused works great most of the time but was at an event last weekend and only got one run in befor it shit on me but when I put her on triLer and got her home it was good to go..
Will be at another drag event this weekend and hope to get at least a couple runs in.
