FlashProManager V1.3.3
Re: FlashProManager V1.3.2 (Beta)
Delete the update.exe file and try again.
nunoctr
Re: FlashProManager V1.3.3 (Beta)
Post by nunoctr »
thanks hondata for the new beta 1.3.3, for the first time I saw today my spoon sports cams going full 50º with the afm (map fuel) calibration
civicRSA
Post by civicRSA »
Great additional features.
Thank you.
[Civic Si] Added boost cut, fuel overrun cut delay, second ECT sensor, VTC cam angle index.
Any chance these can be added to the Euro CTR?
[Civic CTR - Euro] Increased maximum cam angle to 50 degrees, added warm up retard table.
Don't seem to find this table
nunoctr
Post by nunoctr »
I can't find that table also!
the fuel overrun cut delay it's on the Fn2 calibrations for some time.
Next release then.
all-black
Post by all-black »
i dont think the auto gear putting in the teeth makes the correcting to speed. you still have to change add or remove percent to have an accurate speed
For the dash you will still have to correct the speed. However, the ECU speed should be closer.
MJz
Post by MJz »
[Civic Si / Type R] Added VTC deceleration angle control.
I also cannot find VTC deceleration table on Civic-Si-RRC 2-Reflash calibrations...
Go to Options and make sure you have Show Advanced Parameters checked.
MJz
^_^
Post by MJz »
Spunkster wrote:Go to Options and make sure you have Show Advanced Parameters checked.
I'm already set to Advanced Parameters.
Once you check the box you will be able to check the other box. I have verified this is working.
MJz
Post by MJz »
Spunkster wrote:Once you check the box you will be able to check the other box. I have verified this is working.
But in Civic-Si-RRC 2-Reflash calibrations(FD2 Hondata Type R Reflash) not working...
I'm sorry, but that calibration doe snot have the code. YOu will have to use a different calibration if you want that option. It is a preset reflash that does not have the same options as the rest.
MJz
^_^
Post by MJz »
Spunkster wrote:I'm sorry, but that calibration doe snot have the code. YOu will have to use a different calibration if you want that option. It is a preset reflash that does not have the same options as the rest.
I can use other calibration upload to ABA-FD2 Type R ECU?
