Help!!
shawnfuss
Re: Help!!
Post by shawnfuss »
Here is a datalog with me driving it, hopefully this will help you guys help me cause i am lost.
Re: Help!!
Post the calibration as well
shawnfuss
Re: Help!!
Post by shawnfuss »
so i took my car into a car repair place, they said the ecu should be sent to you guys to check it. is this possible?
Re: Help!!
You need to try the ECU in a known working vehicle. If it works propelry then it means there is a wiring fault or sensor problem in your vehicle.
Re: Help!!
shawnfuss
Re: Help!!
Post by shawnfuss »
i got a new ECU and the car runs now, will flood from running the 600cc injectors though. Now i need Kpro swapped over from the old ECU to the new one. how do i go about getting this done
Re: Help!!
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Include a link to this thread
shawnfuss
Re: Help!!
Post by shawnfuss »
do you have any advice on what sensor could cause this problem?? i sent the ecu in to you guys and you said it was good so thats not the problem. a new starting point would be great as this is my only vehicle.
Re: Help!!
Check your wiring as something you have done is not correct. Based on our conversation it sounds like you did something to the wiring at the throttle body and I have no idea why. You may have to take this to someone more familiar with wiring and have them go over everything.
