Page 2 of 2
Re: odd fuel cuts
Posted: Fri Apr 26, 2013 2:36 pm
by Jdogg
ok, do you think it will work if I make a flange for the afm and get it in the pipe even though its a 3.5 inch intake?
Re: odd fuel cuts
Posted: Fri Apr 26, 2013 5:13 pm
Yes, if the reading is roughly correct then it should be ok.
Re: odd fuel cuts
Posted: Sun Apr 28, 2013 8:24 am
by Jdogg
well then.. I'll get to work this week making a flange to put the afm in my intake tube.
Re: odd fuel cuts
Posted: Sun May 26, 2013 7:02 pm
by Jdogg
I put the afm back in the intake. No change. I still get these fuel cuts, and now thanks to the ecu doing this my motor mounts are completely shot. The shock to the car when you're accelerating and the fuel momentarily cuts out is pretty harsh.
Any other ideas?
Re: odd fuel cuts
Posted: Tue May 28, 2013 10:27 am
Can you post the current calibration you are using? From Help, About, what version of software are you using?
Can you also post a picture of your engine bay and show exactly what you have changed.
Re: odd fuel cuts
Posted: Mon Jun 03, 2013 6:25 am
by Jdogg
This is the engine bay. The only difference is the afm is now in the intake pipe
The calibration hasnt been changed at all since it was posted last time. The current version of the software i have is 1.4.4.0
I havent updated or messed with it since it was doing this.
Re: odd fuel cuts
Posted: Mon Jun 03, 2013 10:01 am
Both of the grounds from the injector harness need to be relocated to the valve cover. I can see you have only one relocated and the other is on the manifold.
I cannot see where you have the AFM installed. Can you post a picture of that?
Re: odd fuel cuts
Posted: Tue Jun 04, 2013 6:10 pm
by Jdogg
I dont have a pic of the afm.. Its located in the intake just before the spot where the breather goes back into the intake tube. I'll move the ground wire here in a bit and see if that changes anything
Re: odd fuel cuts
Posted: Thu Jun 06, 2013 7:09 am
by Jdogg
Moved the ground, no change
Re: odd fuel cuts
Posted: Mon Jun 10, 2013 2:24 pm
Jdogg wrote:I put the afm back in the intake. No change.
Have you enabled the AFM? Please send us your current calibration and a datalog of the problem.
Re: odd fuel cuts
Posted: Tue Jun 11, 2013 6:26 am
by Jdogg
Can the afm be enabled and still tune via map? The car runs like crap when its tuned with the afm.
Re: odd fuel cuts
Posted: Tue Jun 11, 2013 10:33 am
Yes, you can tune via MAP with the AFM enabled. With the 2012 Si, this is what you need to do.
Re: odd fuel cuts
Posted: Fri Jun 14, 2013 4:31 pm
by Jdogg
ok, I was thinking for some reason that you had to have the afm disabled to tune with map. I started getting some noise from the head today.. wondering if it broke another rocker arm so it may be a while before I mess with the computer.
Re: odd fuel cuts
Posted: Fri Jun 21, 2013 5:52 am
by Jdogg
initial impression are that turning afm back on fixed it. I'll update in a day or 2.
