SManager V2.2.7 (beta)
Luke
Re: SManager V2.2.5 (beta)
Post by Luke »
i thought, that there wasn't a timer on the chip.
just a mistake by me.
those kind of requests are in the software request thread.
but this is a thread, where you answer. that's really great.
i think, everybody is looking for such a support.
just as I sad: idea - pros/cons - you know, what we would like to have. we know if it's possible.
EDIT: really sorry, Hondata. although I work with the software for so long, but I've never seen that export option! just knew that video export thingy.
my fault! really sorry for that.
best regards Lukas
Johnny_9
Post by Johnny_9 »
Hondata wrote:Lukas, you'll need to clarify your response.
What do you mean about an on-chip timer? What is the purpose of this?
Why can't you export datalogs and use the data that way?
This should be in the software requests thread, so I may move the posts over.
becoz the dataset of the datalog export is (very) limited
whiterabbit
Post by whiterabbit »
Is there some reason why we can't add more than 20 rows to the ignition and fuel tables?
Johnny_9
Post by Johnny_9 »
whiterabbit wrote:Is there some reason why we can't add more than 20 rows to the ignition and fuel tables?
use boost tables
SPOOLIN
Post by SPOOLIN »
use boost tables
he said ROWS not COLUMNS.
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
a nice checkbox that would be good is to disable burnout rev limiter overriding launch limiter (to make use of antilag, and soft limiter for initializing burnout)
www.MSSRACING.com
9.29 | 6.20 | 167
AREA876
Re: SManager V2.2.6 (beta)
Post by AREA876 »
Notice a problem with the Flex Fuel and Close Loop operation (V2.2.6 beta).
Flex Fuel Voltage compensation starts and ends with 5 volts.
Close Loop operation does not take affect until you open and close the setting window.
Can you be more specific? Do you mean the ethanol content compensation table? It goes from 0V to 5V here. If not, post the calibration.
Closed loop operation - do you mean that the ECU runs in open loop, or is there some other setting which changes when you open and close the settings window?
AREA876
Post by AREA876 »
Flex Fuel - after saving calibration it reverts back to the first voltage been 5 volts not 0 volts.
Close Loop - If I'm to switch from open loop to close loop wideband input the other parameters (conditional, short term fuel trim, rate of change) are not activated until I open and close setting window.
SPOOLIN
Post by SPOOLIN »
getting this error after install AND restarting. getting it when i try to open a calibration by double clicking the file. I can load the file from FILE OPEN just fine. This happens with any calibration as well.
see attached.
www.MSSRACING.com
9.29 | 6.20 | 167
rafael_vti
Post by rafael_vti »
SPOOLIN wrote:getting this error after install AND restarting. getting it when i try to open a calibration by double clicking the file. I can load the file from FILE OPEN just fine. This happens with any calibration as well.
see attached.
Same thing here!
SPOOLIN
Post by SPOOLIN »
Win7 64
www.MSSRACING.com
9.29 | 6.20 | 167
Thanks for the report. We've fixed this and will make another release today.
SPOOLIN
Post by SPOOLIN »
Ok let us know.
www.MSSRACING.com
9.29 | 6.20 | 167
ketchu13
Re: SManager V2.2.7 (beta)
Post by ketchu13 »
Thanks for this new release !
Act a fool !
