Traction control - retrofitting abs sensors
Lyle_57IAL
Re: Traction control - retrofitting abs sensors
Post by Lyle_57IAL »
hey hondata !
i am currently in the process of installing my Traction control system. I have basically had to retrofit the rear ABS sensors to my oem arms. As there is a little play with the clearances between the pickup sensor and the Tooth ring - what is a good guide distance / clearance to have between these?
Cheers
It depends on the sensor type - inductive or hall effect. Generally around 1 mm of clearance is required.
Lyle_57IAL
I'm just using some oem sensors off a dc2 go around 0.8mm clearance
Lyle_57IAL
Hey guys. Does anyone have the traction control module wire colour codeing for the 4 wheel sensors ?
Cheers :)
All we have is listed in the help file: http://www.hondata.com/help/tractioncon ... wiring.htm
Lyle_57IAL
not i mean the wiring colour code of the model pig tail itself? what is fr,fl,rr,rl etc
What exactly do you mean? The wire colors for what?
Lyle_57IAL
the wire colour code on the actual hondata traction control unit itself
It that not listed here right at the top?
Lyle_57IAL
Hi Hondata,
Is there any advantage/disadvantage in doubling up or running individually the front and / or rear sensors?
For the front you really need two sensors as the drivetrain and tires will alternately 'wind up' on each side, so a single sensor does not represent the actual wheel speed.
For the rear a single sensor will work ok for a drag car, but for anything else you need two to cope with cornering.
