ABS Module Wiring 2013 Si
08si
Re: ABS Module Wiring 2013 Si
Post by 08si »
Thanks for the link, that was very helpful. I sent the envelope out today so should be there by next Friday. Can you please confirm when you have posted them back so I can gauge when they will arrive? It would be greatly appreciated.
Thanks again for all your help.
08si
Post by 08si »
Hello, I wanted to check to ensure you did receive my S.A.S.E and hoping that it has been sent back. Could you please advise? Thanks.
It was sent out.
08si
Post by 08si »
Thanks!
08si
Post by 08si »
Had this installed today and I'm having some issues. With the TC dial off, it is engaging ignition cut. The only way I can drive without major issues is to turn the TC Input from ELD to None under Traction control in FPM
Also, the TC window within FPM keeps saying Traction Control (disabled - software needs to be updated). I tried updating through FPM with only the TC USB connected and I got no where. I can't do anything with TC from FPM, it doesn't even bring up my owner registration info. At one point I had an Error 6 - Hardware failure.
I downloaded the TC Manager "standalone" software and it seems to give me access to all the features and doesn't give me any messages about updating. I tried calibrating the wheel speed set up,(with TC input set to None so I could drive properly) it provided values for the four sensors, I clicked "update/apply configuration", then reflashed the ECU map with TC Input set to ELD and still no change.
It was installed by a Hondata dealer. I am not quite sure what to do. Any chance you can communicate with the shop directly?
Datalog attached and .cal attached. Please note the .cal is a preliminary basemap.
Karim.AFMAP.SC.Rev06.0.1.fpcal
datalog0001.fpdl
Do not use the standalone traction control software. This can install firmware in the traction control unit which is more recent than what FlashProManager uses (which sounds like the case).
What version of FlashProManager are you using?
08si
Post by 08si »
I am using 1.7.2 Before my car went to the shop, its was connecting with FPM, I am not sure if this is what they used to setup the wheel speed setup.
So where do I go from here?
Download and install the SManager beta software. See if that will recognize the traction control unit. If so, then you can use SManager to set up the traction control parameters.
Otherwise FlashProManager will be updated in two-three weeks, or you would need to send the Traction Control unit to us.
08si
Post by 08si »
I'll try that soon here, thanks. IS the correct method to set the wheel speed set up to press "set" then "apply changes to TC" near the top of the window and that's it?
Yes
08si
Post by 08si »
Can I do that, with the TC Input set to "None"? Otherwise car is next to impossible to drive?
Yes
08si
Post by 08si »
Thank you for the assistance, it is functioning correctly now.
