S-MANAGER NAN is not a valid floating point value
Riphead
Re: S-MANAGER NAN is not a valid floating point value
Post by Riphead »
I think you are confusing me with the guy that originally posted this. I'm not using chinese at all. Smanager loads from the install wizard the very first time after I install it BUT after that it gives me the NAN is not a valid floating point value and won't start.
Sorry, my mistake. In that case, can you send to support@hondata.com the SManager setting file? Go to Options, Settings and there is a button to export the settings. We'd also need the graph templates file from Options, Graph Templates. All the files are in C:\Users\<user name>\AppData\Local\Hondata\SManager if that makes it easier.
Riphead
Post by Riphead »
I think I got it to work. I was avoiding using the BETA prior to last night because I didn't want to deal with glitches, turns out it works for me. So thank you for the help and problem solved.
Johnny_Ek
Post by Johnny_Ek »
Hi, I'm using windows 8 and I tried downloading the SManager for the S300. When I double click it gives me this error code instantly
"'NAN' is not a valid floating point value". I'm unable to get into the program at all. I tried doing a compatibility test and I still cant seem to get it to work. Any help would be appreciated.
Thanks,
What language settings are you using?
Johnny_Ek
Post by Johnny_Ek »
On the computer itself English.
As per the post on the 20th, can you send to support@hondata.com the SManager setting file? Go to Options, Settings and there is a button to export the settings. We'd also need the graph templates file from Options, Graph Templates. All the files are in C:\Users\<user name>\AppData\Local\Hondata\SManager if that makes it easier.
Johnny_Ek
Post by Johnny_Ek »
Ok, I sent it over hopefully I get a response soon. Thanks
Nothing has been received.
Johnny_Ek
Post by Johnny_Ek »
I sent another email yesterday I'm unable to open SManager at all to go into what your asking me to do.
