Android applications
Re: Android applications
also I checked in the sensor list for ethanol % but could not find it
Twin Cam wrote:Is it possible to view ethanol percentage with this app?
i don't see the %ethanol in the sensor list in tha app android ?Spunkster wrote:It can be read in the sensor list in the App.
Bumping this and hoping it might be added on next update? :)Luke wrote: Sat Jun 20, 2015 2:36 am a) change instant MPG also to instant l/100km <- the german/european style (should be only a minor issue, since it's only calculation)
Request: knock control as one of the gauges
Is possible to show on 3rd party app (Torque for example) knock count, AFR, Ethanol % and values like these?
Is there any list of PIDs for configuring these readings in 3rd party apps?
There are some in this document https://www.hondata.com/downloads/Bluetooth.pdfmladjan wrote: Mon Mar 26, 2018 10:12 am Is possible to show on 3rd party app (Torque for example) knock count, AFR, Ethanol % and values like these?
Unfortunately not the real useful ones you mentioned.
Is it possible to have them added Hondata?
The digital and analog inputs would also be awesome to get.
Is there anyway to change the units on the Mobile App?
Also, can we choose what gauges to be displayed and layout?
Hello
Could you please add EGT to the app ?
Thank you all
Thank you all
danielthenerd
Will you be updating the Amazon Appstore version? It is still 1.3. I'm running my backup device Fire tablet and the version on the Amazon Appstore is painfully old.
Slow is smooth. Smooth is fast.
danielthenerd
Yes, I know. The Android fire devices are locked down, so there is no Google play store on it. The only store is the Amazon Appstore.
I'm not sure the current app can distributed on the Amazon store because it uses Google Play.
Hello
Can you please add knock by each cylinders to mobile app ?Because we can not see if there is knock for Fk8.
Thanknyou
Thanknyou
I cannot get the Flashpro to connect to any android device. BT is enabled. Each device "accepted" Flashpro (with the code I set) however the App will not connect - it just blinks...
Is there anyway to troubleshoot this issue @Hondata ? I followed instructions in "help" and any input I found in this blog.
I started a post- no one replied to. I assume there is something right in front of me that is the issue.
