Error code when uploading
Gs-carservice
Re: Error code when uploading
Post by Gs-carservice »
Hondata wrote:But did you close the windows as well as not datalogging? It's taking some time to get you to test these items.
have closed all windows as well datalogging, kmanager seems to download the cal.
i cannot upload any new cal to the kpro, it´s not doing anything at all no clicking etc.
also shows a error in the screen below
thanks
Save the calibration to a file, close and restart KManager. Unplug the USB. Load the calibration (don't download again) then check the calibration tables & parameters. Next connect to the KPro and then upload.
Gs-carservice
Hondata wrote:Save the calibration to a file, close and restart KManager. Unplug the USB. Load the calibration (don't download again) then check the calibration tables & parameters. Next connect to the KPro and then upload.
have saved the cal to a file, closed kmanager unpluged the usb. load the cal and upload it to kpro.
still nothing.
there is no solid green led, but a flashing red one.
thanks
'still nothing' = can't connect to the KPro, can't upload or the car doesn't start?
Can you datalog? Are there any error codes?
Post your calibration here, and the datalog if you can make one.
Gs-carservice
Hondata wrote:'still nothing' = can't connect to the KPro, can't upload or the car doesn't start?
so i can download the cal from the krpo, but i can't upload any new cal's it just don't work.
the old cal keeps comming back when i download from kpro, also when i'm trying to erase the ecu the cal keeps comming back when downloading from kpro.
-can't datalog it doesnt work
i think there is a problem with the kpro no green led is lighting up just a flashing red one.
thanks
I think I understand.
Exactly what happens when you upload? You're going to need to be more specific than 'it just doesn't work'.
Gs-carservice
Hondata wrote:I think I understand.
nothing happens when i upload a cal nothing in the screen or any clicking from the krpo, normaly there is some clicking sound.
i can't be anymore specific then this, is there anyway you can help me out ?
thanks
What is the serial number that is on the K-Pro board that is inside the ECU?
Gs-carservice
Its 10798
You should contact Xenocron Tuning as they are the ones that installed this K-Pro into the ECU.
Xenocron Tuning Solutions
301 Route 17 Unit #5
Hillburn NY 10931 USA
845-504-5340
KPro installer
On site Reflash
email website
Gs-carservice
Spunkster wrote:You should contact Xenocron Tuning as they are the ones that installed this K-Pro into the ECU.
845-504-5340
KPro installer
On site Reflash
email website
Have done that already are there anymore option's ?
Or is it the krpo that's causing the problem maby update firmware ?
They will need to check it out and determine if it is the K-Pro or the ECU that is damaged, or if it is just an installation problem.
Gs-carservice
Spunkster wrote:They will need to check it out and determine if it is the K-Pro or the ECU that is damaged, or if it is just an installation problem.
jun 12,
i have drove the car it was running great but at the time i could not change the cal at all same trouble as above.
so when i got home i erase the hondata kpro, and wanted to upload a new cal these didn't turned out the way i tought it will be.
the car runs the same with or without the kpro, so the kpro doesnt work at all.
is it posibble when erase the krpo the firmware also got erased ?
do you have to copy any license from kpro when you install a new laptop ?
thanks
This has nothing to do with the laptop. You can use any laptop at any time. You need to contact Xenocron Tuning.
Gs-carservice
Spunkster wrote:This has nothing to do with the laptop. You can use any laptop at any time. You need to contact Xenocron Tuning.
just reinstall kmanager with version 3.0.3 from the disc, doesn´t work either won´t dowload or upload any cal´s
get this error code
