FlashProManager v2.2.8
Re: FlashProManager v1.9.7
The upload is working (you can check this by plugging the FlashPro back into a PC). You need to power cycle the ignition after the upload has finished.
J.Dre
Post by J.Dre »
Hondata wrote:The upload is working (you can check this by plugging the FlashPro back into a PC). You need to power cycle the ignition after the upload has finished.
I do that. I've uploaded 94 calibrations to my Si. No problems until I updated to 1.9.7 and firmware 68.
I'll try 1.9.8 and see if the issue persists.
VitViper
Re: FlashProManager v1.9.8
Post by VitViper »
@Hondata
This is a long time coming... can we please get the ability to disable all the EVAP codes in the 06-11 AFM calibrations? Getting a lot of cars popping p0498 and such when they get modded (and well... my car doesn't have an evap system, lol).
matheusorlandini
Re: FlashProManager v2.0.0
Post by matheusorlandini »
how do i update my version if my pc is windows 64bits???!! im using the 1.93 version
FlashProManager works on both 32 and 64 bit versions of windows. What problem are you having?
matheusorlandini
when i accept the update it try to start the download. sometimes it says that the 'files are corrupted.' and sometimes it says that this is not a win32 program...
pepperdanky
Post by pepperdanky »
Download from the link in the first post of this thread.
matheusorlandini wrote:when i accept the update it try to start the download. sometimes it says that the 'files are corrupted.' and sometimes it says that this is not a win32 program...
Normally this is because your anti-virus is deleting the update file.
s2000cr
Post by s2000cr »
I updated to version 2.0.0.0 and I am getting error message "The last Flashpro upload failed. Failure information : Code 0x02 Step 3 Address 0x000000". Please advise.
Are you uploading using a laptop or with the button on the FlashPro?
Does FlashProManager show the ECU with a green tick?
I would reset the FlashPro by unplugging from the car and the USB, then upload the calibration to the FlashPro again.
s2000cr
Post by s2000cr »
Laptop. I removed the software and reinstalled. This solved the problem.
Pir8pete
Post by Pir8pete »
I guess I should have put this in here -> http://www.hondata.com/forum/viewtopic. ... 94&p=79857
pepperdanky
FlashPro help file seems to be down, http://www.hondata.com/help/flashpro/index.html goes to:
Error 404 - Not Found
The document you are looking for may have been removed or re-named. Please contact the web site owner for further assistance.
Thanks for the notification - the online help has now been fixed.
Knox
Post by Knox »
Today, I tried to mapping a jdm FD2 civic type r with flashpro manager v2.0.0. Everything works right when driving in closed loop but when you full throttle car don't turn to open loop. Short term trim be 0% but it looks like engine runs in open loop because I added 10% fuel but air fuel ratio doesn't changed (I turn on the live tuning and it's working on closed loop). I forgot to record a datalog.
On "FD2 Hondata Type R Reflash" calibration "Use Map to determine WOT" is not ticked, I think that it should be ticked because of the FD2 using the map sensor. Am I wrong?
