Difference between 09-10 stock map and 11-14 stock map
GameOver69
Re: Difference between 09-10 stock map and 11-14 stock map
Post by GameOver69 »
Hondata wrote:The injector overrun has been switched over.
The throttle tables are different because a MT calibration has been converted to AT. We've changed FlashProManager so it preserves the table indexes when the calibrations are converted.
The closed loop target lambda tables are correct.
So to confirm, i should have no issues after flashing the stock base map calibration today?
Also besides removing the rev hang, what else can i expect from the stock base map?
A new beta has just been release which should fix all these issues.
You can download the beta here:
gphung
Post by gphung »
Spunkster wrote:A new beta has just been release which should fix all these issues.
I will take a look when I get home tonight, thanks!
gphung
Post by gphung »
On V1.9.7.0 and confirmed the bug fixes :)
One issue though. I cannot log into the Vault. I'm using the forum credentials, and I've tried suggestions mentioned in the other threads to no avail:
  • Case sensitive username
  • Case sensitive password
  • Request lost password and use generated password after re-activation
I've clicked on the Check Internet Connection menu item and it confirms connection is ok. I was also able to look up and get calibrations from the Vault Search, but I cannot log into the Vault explicitly myself.
Thanks, and thanks again for the bug fixes! Appreciate the support.
GameOver69
Bug confirmed.
That's because of the forum upgrade; not FlashProManager. We'll look at this shortly.
