Hitting rev limiter to early?
1qwikef
Re: Hitting rev limiter to early?
Post by 1qwikef »
Have you figured this issue out? im having the same exact issue.. didnt change anything with the car. was out on the street, made a pull was fine. went to make another and now its going in like limp mode. i have changed the cpr box, distributor with no luck.. the logs show it cutting off the injectors around 9200.
You will need to post the calibration and datalogs showing this.
