VSS 155 mph Off= N2O, VTS,RVS,BC Duty
Re: VSS 155 mph Off= N2O, VTS,RVS,BC Duty
I have not been able to reproduce the issue or see any problem on our end. Have you tired taking out the vss sensor and with the key on spin it up with a drill to see what it is doing then? Data log when you do this so you can see if it cutting out at 255 kph.
sass
Post by sass »
Spunkster wrote:I have not been able to reproduce the issue or see any problem on our end. Have you tired taking out the vss sensor and with the key on spin it up with a drill to see what it is doing then? Data log when you do this so you can see if it cutting out at 255 kph.
How do you think, can it be a noise from a cable?
OK. I do the test.
I have three sensors and two ECU k-pro V4 prb
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
