Is this ecu reflashed?
foxone64
Re: Is this ecu reflashed?
Post by foxone64 »
No, I don't have access to a helms manual.
You will need to do this.
YOu may be able to find it online, or you can purchase it from: www.helminc.com
foxone64
Post by foxone64 »
Thank you Spunkster for your diligent help, much is ver appreciated! However, I feel the need to point out the following facts:
1. I didn't have this problem with the 1st reflash
2. After reflashing to this version that code P0172 starts to coming up more often
3. Primary O2 has been replaced with a new one
4. Continuity test was done: A) O2 sensor to plug B) Plug to ECU
If "NEED BE", I can purchase the Helms manual ($47) but in my humble opinion I don't think I should need to. Well, whatever (alternative) help you can still provide will be greatly appreciated.
This is a set reflash that is not changeable. Many many people have gotten this reflash without any issues. There is no way to do a partial reflash. It stands to reason that the problem is most likely caused by something on your end that needs to be found. You really do need to follow the trouble shooting steps for that error code.
