d16z6 supercharged weird behaviour at 1/4 throttle
Re: d16z6 supercharged weird behaviour at 1/4 throttle
It should not be connected directly to the battery. You should connect it to one of the extra spots on the under dash fusebox that is switched. You should also try moving the ground to the thermostat housing.
zone_nord
Post by zone_nord »
that s how i got it wired up first, i tried the battery to see if it makes a difference, it doesn t.
the link is switched with a relay, not always on of course
also tried different ground spots to be sure, thermostat housing was the first option
d16z6 JRSC 6psi
rc440
innovate mtx-l
hondata s300
Post your calibration and a data lot showing the issue
zone_nord
Post by zone_nord »
ok, i ll get that tomorrow morning
your help is much appreciated
thank you
d16z6 JRSC 6psi
rc440
innovate mtx-l
hondata s300
zone_nord
Post by zone_nord »
here is the calibration and a log recorded from home to work
I didn t get any cel this time
I ll keep my laptop connected until I get it
d16z6 JRSC 6psi
rc440
innovate mtx-l
hondata s300
zone_nord
Post by zone_nord »
got it
d16z6 JRSC 6psi
rc440
innovate mtx-l
hondata s300
Try running closed loop with a voltage target instead of a lambda target and see if that has any effect.
zone_nord
Post by zone_nord »
no :(
same cel, got it today
d16z6 JRSC 6psi
rc440
innovate mtx-l
hondata s300
zone_nord
Post by zone_nord »
seems to happen less often when it s colder outside
d16z6 JRSC 6psi
rc440
innovate mtx-l
hondata s300
