KPro4 Lotus K20 questions
blackbenzo
Re: KPro4 Lotus K20 questions
Post by blackbenzo »
I do understand (hondata),but I don't know where to connect the can H and can L to lotus 2005 Elise? I've just took out cluster seems there's a can hook up low and high but cant find the schematic please help out seems I am very close ,yet far....
Do you have the manual (and can you read the poorly reproduced 'manual')? No CAN wire is yellow so I think you have the wrong wire. What model year is the car? Where are you trying to connect the CAN? At the old ECU connector?
blackbenzo
Ok,I got the cluster to work now via can digital outputs,last th8ng is the battery charge light on cluster I need it to read kswap for it to turn off..
My kswao charging system works fine,just need to wire up my kprov4 to the cluster to remove the charge light..
I appreciate all the hard work you fellows over at hondata are doing to get this elise all tied up..
nuclearmuscl523
Post by nuclearmuscl523 »
I have a kswap 05 lotus as well
so its my understanding to get my entire cluster to work all I need to do is tap into the "k-line" wire on the E connector for the ecu, run the (red and blue) lotus CAN H and CAN L wires to their respective outputs on the hondata board, and adjust the multiplex(disabled) digital(disabled) and CAN output(lotus 2005)
