Throttle vs Flow table live tuning doesn't work
Re: Throttle vs Flow table live tuning doesn't work
Gernby wrote:If there is any difference between live tuning and a full upload (in temporary observed results), why would a tuner use it?
There's big advantages in live tuning, not just from the upload speed, but specifically because it does not do an ECU reset. This is important when you are tuning ignition, as every upload resets the knock control and you need to run the engine under medium load for many minutes to get the knock control back down. With live tuning, you can just make a change and do another dyno run.
Gernby
Post by Gernby »
Hmmm ... is there anything that could be done to reset the ECU while live tuning without having to do a full upload? I assumed that clearing DTC's would reset the ECU, so that is usually something I do before clicking update all live tuning tables.
'06 NFR S2000
