FlashProManager v2.4.9 Beta
jthao27
Launch control won't engage...
Post by jthao27 »
So I updated the flashpro manager and reflashed my ecu and now the launch control will not engage. Is there something i'm forgetting or doing wrong. It worked before the reflash and now it doesn't.
Re: FlashProManager v2.4.6
Please tell us what vehicle you have and provide your calibration.
R-12914
Re: FlashProManager v2.4.6 Beta
Post by R-12914 »
Hondata, do you work on a solution for the bugs on a FN2?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
vtecrasr
Re: Launch control won't engage...
Post by vtecrasr »
jthao27 wrote:So I updated the flashpro manager and reflashed my ecu and now the launch control will not engage. Is there something i'm forgetting or doing wrong. It worked before the reflash and now it doesn't.
probably have a 2012-2015 civic si correct? the "new" update shows this under rev limit menu right? i would update mine to upload a cal to this so hondata can see it, but im not giving up launch control lol. although i do have it updated on my work computer, but its at work. and also, it doesnt matter what you put in the blanks. i even filled the table out exactly how the "example" shows in the release note.. the whole use your resume and set buttons on the steering wheel does not work at all!
15 civic si, bolt on's/tuned by cartermotorsports
R-12914 wrote:Hondata, do you work on a solution for the bugs on a FN2?
Did you read my post immediately above yours? A more detailed explanation would be helpful too, rather than 'it does not work'.
#4 is a documentation fault - it should be the set button.
R-12914
Post by R-12914 »
My Car is a Honda Civic TypeR FN2 with a Rotrex supercharger and a hybrid calibration (AFM-Cal with MAP fuel tables!)!
Flashpro Version is the newest 2.4.6.0
and the
Firmware Version is the newest 93.0
#2. Full throttle shift issue:
I have activate the "Full throttle shift" in my calibration like this:
Then i have reflahed my ECU with the new Map!
Now, if i run the engine my full thottle shift over 5900 U/min. and over 80% WOT, the engine revs turns up, even if I press the clutch while driving at full throttle!
So your FTS does not work!
#3. Reflash tachometer progress indicator issue:
If i upload a new calibration via Flashpro to my ECU, I do not see the status of the upload on the revmeter.
It's everything as it has always been!
I hope this helps to fix the issues?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
vtecrasr
Post by vtecrasr »
R-12914 wrote:My Car is a Honda Civic TypeR FN2 with a Rotrex supercharger and a hybrid calibration (AFM-Cal with MAP fuel tables!)!
and the
its not just you, mine does the same thing. basically nothing has changed with the new beta version except loss of launch control
R-12914
Post by R-12914 »
vtecrasr wrote: its not just you, mine does the same thing. basically nothing has changed with the new beta version except loss of launch control
Do you use a AFM or MAP calibration?
It does only work with a AFM calibration!
1. Disable cruise control main switch
2. Press the Clutch Pedal
3. Make Full Throttle (Launch limitier is as set on software!)
4. With the cruise control button "res" you can make increase over 100 rpms
5. With the cruise control button "set" you can make decrease over 100 rpms
6. Launch limiter is set on your required rpms
7. Enable cruise control main switch
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
vtecrasr
Post by vtecrasr »
im not sure.. here is my cal
R-12914
Post by R-12914 »
vtecrasr wrote: im not sure.. here is my cal
Yes, you use a MAP-calibration!
Try a MAF-calibration or a MAF-calibration with MAP-fuel tables like me:
In addition you must hook on the FTS like this:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
vtecrasr
Post by vtecrasr »
mine does use map fuel tables
R-12914
Post by R-12914 »
vtecrasr wrote:mine does use map fuel tables
Yes, but its only a race-calibration (MAP-Cal)!
If you use a AFM or hybrid you have under "Fuel Table Type" the "AFM enabled" like this:
Only then, you have a calibration where the new features, etc. works!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Re: FlashProManager v2.4.5
Post by R-12914 »
the GTR wrote:Can i just copy and paste the values of my custom tune on the new file or do i need a retune?
It is better you make a retune!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
vtecrasr
Post by vtecrasr »
thanks !!
vtecrasr
Post by vtecrasr »
i dont even have that fuel table selection on my end..
none of the cal from "open new calibration" for the 2012-2015 civic si have that fuel type tables with more than one option
