S2000 AC not Working
spoon.ap1
Re: S2000 AC not Working
Post by spoon.ap1 »
First turn the key in the on position, turn the fans on max and wiggle the relay side to side to confirm that is the issue. If that's the issue, then proceed below. I would look for another relay or trigger to wire it up to, maybe the ignition relay.
A quote from this thread:
http://www.s2ki.com/s2000/topic/795972- ... check-for/
"Well... I tinkered on and off for a good hour or two with nothing but a sign that the fuses weren't getting any power. I had a crazy thought last night to install my old relay tap (tap only with no wire leading anywhere)
And it worked. I guess installing the relay tap had expanded the metal contact inside the plug, so it needed that extra thickness to make the electrical connection."
SCS2K
Post by SCS2K »
Thank you for the response! It ended up being a cut wire and it was a pain to find. All is well now though. Thank you both for the help
thank you for letting us know
