Hondata s300 red led flashing fast
Re: Hondata s300 red led flashing fast
Since you purchased the s300, has it ever worked?
jose_mbk
Post by jose_mbk »
No not yet. The mount a week ago
jose_mbk
Post by jose_mbk »
The Ecu works. The pc detects it. I can upload calibrations. I have both green LEDs on. But the smanager does not read sensors. The engine starts, the car moves. But it does not exceed 2500rpm and goes off in idle.
Where did you purchase this s300 from?
jose_mbk
Post by jose_mbk »
A US seller sent me to Spain
Who was the seller? We need to trace the S300 back to us.
jose_mbk
Post by jose_mbk »
Already solved. I just had to disable two injector errors and Baro
jose_mbk
Post by jose_mbk »
I was not a store seller I was a person who bought it and I did not get to use it
jose_mbk
Post by jose_mbk »
Thank you for your attention. Good service
forevertrj
Post by forevertrj »
I just finished having an issue like this, My red light was flashing and no solid green light at the USB connector, what I found was the main board( Green Honda ECU) needs to be clean of all flux used during the socketing process as voltages will bleed to other connectors and cause very erratic behaviors or not even work at all. Also I pulled both hondata and the ecu(green board) out of my aluminum case and tested continuity from the back of the green board to the top of the white(hondata s300 v3) for all the 14 header pins to make sure there was a solid connection. also on the second rail of 14 headers and the 4 pin datalogger header. If issues persists replace the stock ecu's capacitors and again clean the board of all flux or (soldering assist material)
