Page 2 of 2
Re: FlashProManager 2.6.7.0 & 2.6.8.0
Posted: Fri May 12, 2017 3:41 am
by R-12914
typer86 wrote: Fri May 12, 2017 1:17 am
Today updated the firmware from 2.6.6.0 to 2.6.8.0
Issue:
The orange LED is very dark after the update! It is hard to see if the log is started or not.
It look like a little "glow" like a old LED.
Please check it.
My Flashpro is ~4 years old without BT
Same here!
Posted: Mon May 15, 2017 1:08 pm
by fizeks
R-12914 wrote: Fri May 12, 2017 3:41 am
Issue:
Please check it.
Same here!
can confirm the orange LED is very dark as well ever since the 2.6.8.0 update. could not see if i was datalogging or not. My flashpro is also without BT if that makes a difference.
Posted: Fri May 19, 2017 10:31 pm
by fizeks
i updated to the 2.6.9.0 flashpro manager earlier today and safe to say that the orange datalog led issue is fixed for me. all back to normal now thanks!
those with the issue should update for the fix.
Posted: Fri May 26, 2017 7:16 am
by Arwin21
Hi,
after the last update 2.6.9.0. the radiator fan of my Civic Type R FN2 doesn't work.
In the traffic the engine has reached 98°C (!) and the fan has not activated. I'm worried ...
I use the Group N calibration.
Posted: Fri May 26, 2017 7:22 am
Nothing has been changed for the FN2. 98C is not high for coolant - the fan normally will not switch on until the radiator return reaches a certain temperature, no the cylinder head outlet temperature.
Posted: Fri May 26, 2017 7:45 am
by Arwin21
In Gr.N calibration on the "misc parameter" page there is
Radiator Fan ON 93°C
Radiator Fan OFF 90°C
Posted: Fri May 26, 2017 11:29 am
The fan is switched based on the radiator return temperature (ECT2) and you're looking at the cylinder head outlet temperature (ECT).
