s300 v3 + LC1
Re: s300 v3 + LC1
Try connecting the ground to the ECU ground instead.
rofeksos
Re: s300 v3 + LC1
Post by rofeksos »
Spunkster wrote: Mon Aug 21, 2017 12:42 pm Try connecting the ground to the ECU ground instead.
Hi Spunkster. Is this the ground wire going into the ECU itself or am I using the ground wire located on the thermostat housing?
Re: s300 v3 + LC1
Either should work.
rofeksos
Re: s300 v3 + LC1
Post by rofeksos »
Spunkster wrote: Mon Aug 21, 2017 3:23 pm Either should work.
So I connected the wideband's ground to the thermostat ground and it looks like it's reading everything correctly. However, there is a small delay which seems to show that the ECU is a bit slower than the gauge. Is this normal?
Re: s300 v3 + LC1
There will always be a slight delay as the wideband controller is getting the signal first then converting it and sending it to the ECO to be processed.
