Kpro not being picked up by laptop anymore
Re: Kpro not being picked up by laptop anymore
post a picture of what you are describing
Girn
Post by Girn »
Spunkster wrote: Tue Oct 24, 2017 10:01 am post a picture of what you are describing
Top right pin was bent all the way in, tried by best to pull it back out with tweezers and straighten it. But it's too difficult to get it back into its original shape to make a circuit. Another pin was also bent slightly
The K-Pro is damaged and will have to be replaced/upgraded. You can use the upgrade form at: https://www.hondata.com/downloads/kpro4 ... e_form.pdf
Girn
Post by Girn »
Spunkster wrote: Tue Oct 24, 2017 10:32 am The K-Pro is damaged and will have to be replaced/upgraded. You can use the upgrade form at: https://www.hondata.com/downloads/kpro4 ... e_form.pdf
Thanks for the reply, I took off the ECU and gave it one more attempt. Low and behold it worked! Tried uploading a new map and it worked out, thank God. If I have further issues I will send it again.
