Installing Hondata Mobile on your 10th gen Civic radio/navi
Re: Installing Hondata Mobile on your 10th gen Civic radio/navi
No, it will not.
patrikspacek
Post by patrikspacek »
Guys, I got stuck here: (I have TypeR 2020)
"D) Install the Hondata mobile App
6. Press the top backslash or '..' to go backwards and then scroll down to 'usbdrive2'.
7. Select the com.hondata.hondatamobile.apk file."
Where can I get this .apk file?? I cant find any like this. So I uploaded this one on USB: Hondata dash apk
I put my USB drive into USB port and I cant see the file (root), I cant install it.
patrikspacek
USB fixed: USB needs to be change back to Host (nothing mentioned in installation guide) to make USB working again.
Bluetooth problem (video below):
1. Bluetooth set up in Manager, code 0000. Hondata app connected to FlashPro successfully. (good, Samsung S10)
PROBLEM: Flashpro visible on Bluetooth list of the radio, then tapped on Flashpro and number 0000 was automatically sent, then screen with Unable to connect.
My VIDEO showing my process (1min):
https://drive.google.com/file/d/1T1htND ... sp=sharing
Thanks for help.
What have you got the 'alternative pairing mode' set to?
patrikspacek
Alternative unchecked (image attached)
some people said i have old app... i downloaded honda dash apk from Hondata website...is there another one?
patrikspacek
so i changed it to alternative 2018+ and I was connected, But Hondata app has problem with connections and crashes.
Sometimes gauges pops on for 1s and crash again.
Then connection failed all the time.
patrikspacek
Here is a short video when HondataApp crashes, this is happening all the time.
https://drive.google.com/file/d/13wPVrb ... p=drivesdk
patrikspacek
Hondata mobile crashes
Hondata Dash App 1.5 - crash
Hondata Dash App 1.5.4.1 - crash
everytime on start, even it says its connected.
I will try to find 1.3 version, if its stable.
Re: Hondata mobile crashes
Do you have the alternate pairing mode enabled?
patrikspacek
yes, otherwise the Flashpro wouldn't run at all :)
but the app is crashing like crazy, very unstable.
We have not made any changes to the app and it runs on all the other vehicles without any issues. You might try a hard reset of your head unit by holding the power button for 10 seconds.
patrikspacek
I did reboot a few times, and it still crash while starting. It might also be communication between flashpro and dash. I would need to discuss it with somebody who has TypeR 2020. It just doesnt work for me.
patrikspacek
It can also be versions conflict between dash and flashpro... Hondata should make a new installing video for 2020 version to prove its working.
patrikspacek
Well, I paid for the Android app and even it says its connected to BT, there is no any response on gauges from the car. So I believe, their paid app, doesnt work on Samsung S10 and it may also cause Hondata dash app crashing all the time. Based on what I see, coders should do a better job of testing.
Are you trying to connect to more than one device at the same time?
