Please quick help to unlock Flashpro from vehicle!
R-12914
Re: Please quick help to unlock Flashpro from vehicle!
Post by R-12914 »
Hondata wrote: Sun Mar 11, 2018 3:09 pm Glad it is working.
We do not want to allow the immobilizer to be disabled in the interests of preventing theft.
Could you allow it, that i can drive to the dealer and re-program the immobilizer?
That would be great!
Thank you!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
This is not something that will be allowed. You will have to tow it to the dealer to match the key an immobilizer.
R-12914
Post by R-12914 »
I remember, on the reflash Ecu, the immobilizer are always disabled as standard...
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
We have never disabled immobilizers with reflashes.
R-12914
Post by R-12914 »
Hi Hondata,
now, I have the new ECU installed by the dealer and let enter the immobilizer.
Now I could lock my flashpro to the new ecu, but I can not unlock it anymore.
The dealer forgot to enter the VIN number from my car into the ECU, I would like to do it now.
I have just sent the information to you!
Please help me fast!
Thank you!
BTW:
This error message pops up, if i like to unlock from the vehicle:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Why are you replacing the ECU?
If the FlashPro is locked to a different ECU you must first return that ECU to stock then unlock it to be able to use it with a different ECU.
R-12914
Post by R-12914 »
Spunkster wrote: Thu Mar 22, 2018 3:16 pm Why are you replacing the ECU?
therefore:
viewtopic.php?f=28&t=20991
Spunkster wrote: Thu Mar 22, 2018 3:16 pm If the FlashPro is locked to a different ECU you must first return that ECU to stock then unlock it to be able to use it with a different ECU.
Yes, I know that and I have already done that!
This is another bug in your software!
Please fix this problem immediately!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Why has this been locked and unlocked so many times, and with different vehicles?
R-12914
Post by R-12914 »
The new Ecu is a used part, where i have build-in.
The VIN of the new ECU is different from the VIN of my vehicle.
Do you understand?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
Do you have fix this problem now?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
edit:
it's been dealt with!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
I have the following problem:
The Flashpro is now locked to the new ECU (the VIN of my car already write into the new ECU via Honda HDS).
You can see this on the "ECU" Table.
But under "Licence" you can still see the VIN from the donor car, where the new ECU comes from.
After converting to the new ECU into my car, I was able to lock my Flashpro to this, but I can not unlock it anymore, to put the correct VIN (from car and new ECU) also as Licence.
Please help/fix this problem and let me know!
Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Please email us with an exact timeline of what has happened. We can't work out exactly what you have done from this end.
R-12914
Post by R-12914 »
Hondata wrote: Fri Mar 23, 2018 5:04 pm Please email us with an exact timeline of what has happened. We can't work out exactly what you have done from this end.
Ok, thank you!
I have just sent you an email with the exact problem area and timeline!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
The same thing happens, when the condition is as follows (see VIN):
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
