Battery Light ON after KPRO v3
gabyz1
Re: Battery Light ON after KPRO v3
Post by gabyz1 »
I’ll try with the battery.
If it was the alternator, I would drained my battery long time ago.
gabyz1
Post by gabyz1 »
Spunkster wrote: Mon Apr 02, 2018 4:41 pm Could be the alternator, battery or any wiring in between.
The weird thing is that I plug my stock ECU and no battery light. Could it be a ground location?
Its hard to say what it might be if the ECU works on a different vehicle. All you can do is use the process of elimination.
gabyz1
Post by gabyz1 »
Spunkster wrote: Tue Apr 03, 2018 10:20 am Its hard to say what it might be if the ECU works on a different vehicle. All you can do is use the process of elimination.
What do you mean?
You must rule out one thing at a time, swapping in known working things from other vehicles if needed.
Alexdc5rsx19
Post by Alexdc5rsx19 »
I would assume it’s related to just my car but it’s more then just me that has this problem I called Hondata and they were dumbfounded as well they thought it was because my software was outdated which is wasn’t but it’s driving me crazy that the battery light on.
I do have a question to who all Have the Kpro ecu with battery light on. Do you guys have replaced alternators? If so are they oem? Because I think I may have figured it out but I need more testing to be done because I notice A LOT of rsx owners have this problem with Kpro
Alexdc5rsx19
I think I may have figured it out but I don’t know how to post pictures on threads tho lmao.
gabyz1
Post by gabyz1 »
Alexdc5rsx19 wrote: Thu Apr 05, 2018 12:53 am I think I may have figured it out but I don’t know how to post pictures on threads tho lmao.
You can try to explain it, it’s okay.
jaybonics
Post by jaybonics »
I know this is a few years old thread but I'm currently in same boat. And this thread ends I think I figured out well is there results lol. I replaced with a oh oh oh crappys tried multiple out in there lot . So is the issue I need new alternator that's oem. ?
Spunkster wrote: Wed Apr 04, 2018 10:03 am You must rule out one thing at a time, swapping in known working things from other vehicles if needed.
808to702
Post by 808to702 »
Has this ever been figured out? I have my own post I just posted but figure I bump this up maybe someone can email me what they did to fix theirs. 1992bjm3@gmail.com
808to702
Post by 808to702 »
Spunkster wrote: Thu Mar 22, 2018 3:12 pm responded via email.
Hey spunk did you guys ever get this figured out? I’m having this issue now after installing Hondata. I have searched and have not found anyone’s fix. Everything seems to be in order. Alternator output is within specs. Battery tested good. Grounds all checked out and cleaned. Only comes on with this hondata ecu in. Installed back into the 05 rsx it came from and light is not on. When I put my stock ecu in my 06 rsx the light is not on as well. ONLY when the ecu with hondata is installed then I have a battery light on.
13btoy
Post by 13btoy »
Good morning guys. I just recently installed a V3 on my sons 2005 RSX Type S. As soon as I fired up the car the Battery light came on instantly and has been on as well. Kpro display is reading normal at idle @14.2 volts even with battery light on. Did we ever figure out the fix for this issue?
Thanks, Ed
