CTR FlashPro tuning - fuel pump
jurgen2212
Re: CTR FlashPro tuning - fuel pump
Post by jurgen2212 »
I have Flashed my 2018CTR and installed the high pressure fuel system upgrade.
The Falshpro will not allow me to enter the serial number and software key.
Tried everything and Hondata has been unable to help so far.
Have you contacted us yet? Please email support@hondata.com with the serial number you are using.
This was resolved yesterday, it had already been activated in the software.
ayau
Post by ayau »
What’s the duty cycle on the factory map? Also 95%?
Do the Hondata maps have the air charge adjusted to ensure duty cycle doesn’t exceed 95%, or is it critical that the end user periodically performs data logging just to confirm?
Do you mean the fuel pump duty cycle with the Hondata Fuel System? It depends on the fuel used. I believe it is around 70% on pump fuel.
And the answer to the second question is that it is a good idea to check knock retard, lambda and fuel pump duty cycle on any vehicle.
ayau
Post by ayau »
Hondata wrote: Sun Jun 21, 2020 6:33 am Do you mean the fuel pump duty cycle with the Hondata Fuel System? It depends on the fuel used. I believe it is around 70% on pump fuel.
I meant the duty cycle on a completely factory car (factory map, factory fuel system, etc).
You can't datalog from a 100% factory vehicle because it does not datalog the fuel pump duty. But I'd guess it is around 80%. Duty is not linear with volume however, so it is not 80% of capacity. What are you trying to determine?
ayau
Post by ayau »
Hondata wrote: Sun Jun 21, 2020 12:04 pm You can't datalog from a 100% factory vehicle because it does not datalog the fuel pump duty. But I'd guess it is around 80%. Duty is not linear with volume however, so it is not 80% of capacity. What are you trying to determine?
I was just trying to compare the duty cycle of a factory tune with a Hondata tune but it doesn't sound like the percentages are linear, which makes it difficult to compare.
Jfink
Post by Jfink »
I am running full bolt and meth kit & my fuel duty cycle has hit 100% on some WOT pulls and I experience sputtering . Can I get some help with what I could do?
Joe_typer
Post by Joe_typer »
I am having an issue where after fuel system installation my flashpro automatically says pump enabled and will not let me put the serial and software key. I need help on hot to know if it is working or not so confused right now. Please see attached screenshots
If it shows enabled then you do not need to do anything further. I also answered the feedback information you sent.
Joe_typer
Post by Joe_typer »
Thank you! I just wanted to make sure everything looked good before I push the car for some datalogs
