Kmanager On line Ignition Off
Re: Kmanager On line Ignition Off
Have you tried disabling the ELD in the calibration?
AresGR
Post by AresGR »
hey spunkster, no i dont have. I dont know if its okay to disable it.
If it is okay i would disable it under "misc" right?
Today i have made a Datalog and i had another error Code P0132 Oxygen Sensor... First it was 1.4V and then after 5 mins. 4.1V. After that it felt down to 1.4V again...
AresGR
Post by AresGR »
Anyone can help me out with p0132 oxygen sensor high voltage? Wiring is correct but i get this error code in kpro :/ i have a datalog too...
Has this been tuned on the dyno?
AresGR
Post by AresGR »
no, not tuned on dyno
This sounds like a tuning issue, I would recommend that you get this properly tuned on the dyno. The tuner should be able to resolve this issue.
You can also follow the factory service manual for troubleshooting that error code.
AresGR
Post by AresGR »
Ok. Spunkster can i give you my calibration and datalog? Maybe you can see if something is not correct in settings or something like that?
Thank you, great support!!
