S300 AUX settings/problem?
EFB055
Re: S300 AUX settings/problem?
Post by EFB055 »
Is there any chance the installation is the reason these functions aren't working? Can i visually identify if something has not been connected correctly?
If both A17 and A10 aren't supported by my ECU, should i try repinning the output to a different pin? For example A20 (purge control) or A15 (AC clutch) which i'm not using?
Purge may not be supported on that ECU either. AC clutch may work.
Installation shouldn't have anything to do with these inputs/outputs, but it is not installed correctly and could cause issues at some point.
EFB055
Post by EFB055 »
I selected the AC pin in Smanager, re pinned the connector and got the function to start working. Thanks for your help.
