HELP!!! I need a calibration for my 2002 Base K20a3 w/ PRB KPRO ECU
XDarkPrinceX
Re: HELP!!! I need a calibration for my 2002 Base K20a3 w/ PRB KPRO ECU
Post by XDarkPrinceX »
Been tuning out the fuel maps manually and going kinda slow using normal driving datalogs, really getting the partial throttle tuning down more then anything as WOT is pretty spot on, however I wanted to use autotune for the partial throttle to get it even closer (within .05 - .1 A/F : Command A/F) but I can't seem to get autotune to start, I selected the tables for it to auto tune 0/10/20 degrees on low speed and the live button only stays yellow on those tables.
1. selected tables
2. uploaded calibration
3. started engine
4. started data
5. autotune is greyed out???
It only autotunes while CTRL-T is held down and you must be datalogging with the calibration open when doing this.
XDarkPrinceX
Well that's unfortunate, so if I select my 3 tables to tune, upload to ECU, start car, start datalogging I could have someone hold CTRL+T even though its greyed out on the toolbar?
Autotune will only work with PRB based calibrations.
