Hondata Mobile APK 1.5 (Android) for Dash
Re: Hondata Mobile APK 1.5 (Android) for Dash
Good to hear. Now I need to add some more channels to the dash app.
high718
Post by high718 »
awesome thumbs up.
high718
Post by high718 »
Just a question do you have to power cycle it every time you start the car. Because I leave the flashpro plugged into the cars obdII. It auto connects to Bluetooth on the heatunit when I start the car but when I try to connect to the app it says connection fail. Or should I just unplug and replug every time I want to use it
No, you should not need to power cycle the FlashPro. We'll test here and see if we can reproduce that behavior.
high718
Post by high718 »
Roger. like i said it auto connects to the headunit via bluetooth every time. its just the app that doesnt auto connect.
File for testing
Hondata-Dash-App-v1_5b.apk
high718
Post by high718 »
testing now
Taco619
Post by Taco619 »
Had the same issue as high718. Tried out Hondata-Dash-App-v1_5b, and it paired with the app! Great job Hondata!
2018 Si Sedan
FlashPro 3.1.3.0
HondaHack 4.2.9
Hondata Dash 1.5_b
Head Unit:
Model Number MY16ADA
Android Version 4.2.2
Kernel Version
3.1.10+
jenkins@NDYWY3861584#1
Build Number 1.F1A1.25
Here is another app to test
Hondata-Dash-App-v1_5.apk
1. Connect the dash to your phone via wifi.
2. If the app does not connect, go to settings, then scroll all the way down to log file. You can send use the log file via your phone wifi hotspot.
high718
Post by high718 »
Sent 4 logs
Taco619
Post by Taco619 »
Tested new 1.5 .apk two ways. First was by just uninstalling 1.5b, power cycling car, and installed 1.5. App connected to FlashPro the first time. Second, a complete uninstall of the app, and Bluetooth pairing. Re-paired Bluetooth, installed 1.5. App again connected to FlashPro the first time.
Thanks for the logs.
Taco619: it seems to depend on the vehicle, so your 2018 may be ok.
Here the current test version with logging.
Hondata-Dash-App-v1_5_1.apk
high718
Post by high718 »
Auto connects the first 4 times. ill send logs if it doesnt. so far so good.
high718
Post by high718 »
Sent two logs yesterday and here is a picture of the screen. Auto connects more frequently now more then ever.
