Engine misfire
Civic 2016+ 1.5 Turbo
Re: Engine misfire
attach the calibration here please.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
as requested
Re: Engine misfire
Have you installed any aftermarket parts on your vehicle?
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Hi! :-)
Nothing, everything else is stock. What I have also notice is that the acceleration versus pedal position is off...
The miss fires started after the Honda recall.... don't know if is a coincidence...
Do you think I need to change the calibration!? They are 3 possible for Civic 2017 with manual...I have a hatch Sport... don't know if it make a difference...
Re: Engine misfire
Download the most recent version of software.
Upload your calibration to the ECU using that software and see if the issue persists.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
That's what I'll do for the acceleration problems but, for the miss fire, that's been happening in every version of the software since April...
Re: Engine misfire
If you go to the online menu and use the return to stock function, do you still get the misfire errors?
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Also, can you tell me witch of the calibration is adapted for the Hatch Sport?
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Yes i do have the misfire on stock Version as well
Re: Engine misfire
If you have the misfire after returning to stock then you should take the vehicle to the Honda dealer for diagnostics.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
ok thank you, I'll bring my car to the dealer! I'm assuming their is no difference between calibrations?
Re: Engine misfire
With your FlashPro plugged in to the laptop it will only allow you to open calibrations that are compatible.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Strange...because it allows me to select SI calibration as well...
Re: Engine misfire
With it plugged in, when you click new calibration it will automatically show the calibrations that are compatible with your vehicle without you having to select anything.
ElpacoSV
Re: Engine misfire
Post by ElpacoSV »
Hi, reporting that I have the same choices as before...even SI, 2018, etc...if their is no problem me choosing from:
Civic 1.5T Canada 2017 MT Or Civic 1.5T Canada 2017 Hatch MT
I'm ok with it :) Is just my OCD kicking in I guess HAHAHA
