2018 Accord Rev hang disable issue
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
andyswmr714
Re: 2018 Accord Rev hang disable issue
Post by andyswmr714 »
I have retested as suggested with Hondata FlashProManager V3.4.4.0.
Cruise Control does work now with Rev Hang Disabled. YAY!!!
Attmpted 42 mph cruise. Then set to really high mph. Then car drives until stable.
The problem i still see though is that Rev Hang still occurs even though it is disabled.
I have annotated those issues in the log. I don't think it is the lightweight flywheel.
It is very obvious at higher rpm. At lower rpm it doesn't occur as drastically.
Any time Cruise Main is on, rev hang will return to normal as well.
andyswmr714
I can confirm. Main enabled rev hang is on and cruise works. Main disabled rev hang is disabled.
There is a noticeable engine tone difference when enabling disabling main.
Can you describe what that could be from? Or Do you need a log?
Thanks!!! I am so happy Both are now working!
That is by design so that the cruise works properly.
