How to connect a MTX-L Plus wideband digitally
AREA876
Re: How to connect a MTX-L Plus wideband digitally
Post by AREA876 »
Did a custom conversion and got the analog to match but digitally that's where I'm having the problem
Can you show me what it reads when set to LC1?
AREA876
Post by AREA876 »
Analog 3 is my wideband and it was reading 2.28 when the innovate was reading 0.97 lambda
What have you programmed with MTX analog output as? Mine used the change every time the connector got wet...
AREA876
Post by AREA876 »
Custom conversion I was using at the time. Please ignore the highlighted AF as it was set to the wrong input.
AREA876
Post by AREA876 »
The default innovate values are 0V = 0.5 and 5V = 1.52 Lambda
Yes, but what are the actual values the innovate has? Like I said, mine used to change on its own.
AREA876
Post by AREA876 »
Values have not changed, I have never had a problem with values changing and I have owned two LC1 and a MTX-L
So now switch the analog input to voltage and check it matches the lambda.
AREA876
Post by AREA876 »
Voltage at key on engine off and sensor has been heated, MTX-L is displaying 1.52 on the gauge
AREA876
Post by AREA876 »
Screenshot of raw voltage and MTX-L at idle
I've checked and both the KPro and KManager use the 0.5-1.5 lambda range for the LC2 analog input. So they should work.
So is only the digital input the problem? In that case can you set the analog to LC2 and compare the digital to analog when both datalogging, and also by making a datalog on the KPro and then loading into KManager.
AREA876
Post by AREA876 »
Key on engine off sensor heated readings doesn't match
LC2 Conversion vs Digital Input.kdl
Thanks. It is something with the digital stream which is different from the LC2. I'll try to get Innovate to respond again.
AREA876
Post by AREA876 »
Any updates
