air con problem
Re: air con problem
The engine is not running in that datalog.
haRRibo
Re: air con problem
Post by haRRibo »
sorry for late
can you please look on this?
Re: air con problem
In this datalog your engine does not appear to be running.
haRRibo
Re: air con problem
Post by haRRibo »
sorry for late
Re: air con problem
The ACSW is not showing on, so there may be a problem with your adapter harness you are using.
haRRibo
Re: air con problem
Post by haRRibo »
All pins on the harness are correct for the A/C.
On OBD1 the pin for the A/C relay is A15 and the pin for the A/C switch is B5
On the OBD2a the A/C relay is A17 and the pin for the A/C switch ia C5
I did a double check of all cables and are OK.
But I can buy a new one.
Can you reccomend me any good adapter harness????
Re: air con problem
What is the part number on your ecu?
haRRibo
Re: air con problem
Post by haRRibo »
These numbers are on my ECU:
37820-P30-G00
775-104361 1A14
Re: air con problem
Remove the s300 and cut J1, this will allow the ECU to run as stock. See if it works properly then.
haRRibo
Re: air con problem
Post by haRRibo »
I removed the s300 and connected the ECU to the car.
The ground signal to the AC clutch disappeared. Looks OK.
But I can't run the car with this ECU without hondata because is from 1,6 engine and I have 2,2 turbo.
Do I have to still cut J1?
Re: air con problem
J1 must be reconnected to use the s300.
haRRibo
Re: air con problem
Post by haRRibo »
OK I did it.
The ground signal to the AC clutch disappeared. Looks OK again.
haRRibo
Re: air con problem
Post by haRRibo »
any advice?
Re: air con problem
So it is working correctly with J12 connected?
haRRibo
Re: air con problem
Post by haRRibo »
only J1 is reconnected and looks OK
