Unlocking flashpro from damaged ecu
Re: Unlocking flashpro from damaged ecu
The ECU is in recovery mode so it is working. Battery voltage is as low as 8.6V.
What you need to do is put a battery charger on the vehicle and keep uploading until it comes out of recovery mode.
I'd still like to know why the ECU was opened.
KaywayRiley
Post by KaywayRiley »
I put a brand new battery in the car the ecu clicks in and out when connected to the flashpro in the process of returning the ecu back to stock it disconnects the ecu was not opened it was damaged i said the person touched the battery together terminal to terminal the terminal was melted the fuse didnt blow and the ecu was damaged from it the car ran for a day after that it started shorting out the whole car is shorting out but now its Not starting or anything anymore look i just wanna unmarry it from this damaged ecu so i can order a brand new ecu and continue driving my car i sent the feedback report the old battery is in the car now the battery voltage said 12.8 when i was uploading that
KaywayRiley
Keep uploading ?? Keep uploading what the big triangle in yellow is on the side of the ecu icon at the bottom and it says vin not recognized everytime i try to do anything with the hondata i press unlock from ecu it says the vin is not recognized
KaywayRiley
Ok i uploaded it back to stock but I’m getting error authorizing vin please contact support@hondata.com now I checked my internet and it’s okay
Just not unlocking now
IT is in recovery mode. That just means that you need to upload a calibration and it will be out of recovery mode.
KaywayRiley
It’s out of recovery mode but it’s saying error authorizing vin
What is the serial number that is on the FlashPro?
KaywayRiley
FP-SI-US-17965
KaywayRiley
Should i try it now ??
It should unlock now.
KaywayRiley
It did thankyou so much... may i ask what is the cause of that error code so i know how to avoid it in the future or is that out of my control
You're trying to use one FlashPro for two vehicles. Lock it to one vehicle and don't unlock it.
KaywayRiley
That was before but this time it’s on one vehicle it’s just the ecu got damaged so imma use the new ecu and lock it to this one for good
KaywayRiley
Ecu got damaged and the flash is stuck on the old ecu again
KaywayRiley
Spunkster wrote: Tue Dec 03, 2019 10:06 am What is the serial number that is on the FlashPro?
Hey spunk i need a hand again ecu blown and I can’t get the flash off it’s saying error again my mechanic did some bad work and blew the ecu during a rebuild
