Help - Car cuts off Check engine light but no Code? (log added)
Re: Help - Car cuts off Check engine light but no Code? (log added)
Try swapping in a stock map sensor after changing the settings for it and see if the issue is resolved. If it is then you have a bad map sensor.
jetspeedz
Post by jetspeedz »
Thanks, that is my plan, i don't have a stock map sensor but will order a new 4 bar map sensor via amazon and test. If it's not the map sensor it has to be the wiring harness on that sensor.
Is there a way to zoom out to the whole datalog if setting new start and end time?
Once you set a new start and end point the rest of the data is lost.
jetspeedz
Post by jetspeedz »
Got it thanks a lot.
DA9LEO
Post by DA9LEO »
I noticed in your boost control settings in your parameters, you have pwm activating at -10.1 inches of vaccum. maybe look into the duty cycle and how you have your pwm setup in that table also
jetspeedz
Post by jetspeedz »
It was a bad Map sensor, replaced it with a Omni 4 Bar and its driving perfectly normal again. The owner at Omni is awesome that is all I can say.
